cwuestusa
Mar 26, 2017Aspirant
Cannot find option for Firmware update when I login to my R6400 AC1750 wireless router
When I login to my R6400/AC1750 Smart WiFi Router from my MAC computer using www.routerlogin.net, I cannot find a function to update my firmware on my router, or search for a new firmware version or to have my router update its firmware automatically. The Router Settings Box does not appear.
Yes it was in advanced setting >> administration >> router update, thank you so much for helping me find it!!!
- VE6CGXMaster
After logging into the router where are you looking? It should be in the advanced setting >> administration >> firmware
- cwuestusaAspirant
- TxAnd_48Aspirant
I can not find an Advanced Settings function on my router.
- DexterJBNETGEAR Moderator
Hi TxAnd_48,
You may find the links below helpful.
http://kb.netgear.com/app/answers/detail/a_id/24217
http://kb.netgear.com/app/answers/detail/a_id/23960
Dexter
Community Team
