firozp
Jul 16, 2018Aspirant
cannot find wireless repeating function in my D1500's console settings
Hi,
I am trying to enable the wireless repeating function on my D1500 router. As per the instructions there should be an option called "Wireless Repeating Function"
in the advanced settings o...
- Jul 17, 2018
Weirdly i the option showed up after downgrading to the firmware version: D1500_V1.0.0.15 and it works perfectly :smileyhappy:
Not sure why it was removed in the newer versions.
Thanks for your time anyway antinode
firozp
Jul 17, 2018Aspirant
Hello antiNode,
Really appreciate the quick response !
Firmware version is V1.0.0.27_1.0.1PE
I have attached a screenshot of the console.
I read about the function in the online FAQ at https://kb.netgear.com/26900/D1500-FAQ-s (section Can D1500 act as a repeater?)
antinode
Jul 17, 2018Guru
That all looks reasonable, unless you expect reality to agree with
the documentation. Have you tried the official Netgear support
channels, or would that now be costly?
- firozpJul 17, 2018Aspirant
