firozp's avatar
firozp
cannot find wireless repeating function in my D1500's console settings
Hi,   I am trying to enable the wireless repeating function on my D1500 router. As per the instructions there should be an option called "Wireless Repeating Function" in the advanced settings o...
  • firozp's avatar
    firozp
    Jul 17, 2018
    Weirdly i the option showed up after downgrading to the firmware version: D1500_V1.0.0.15 and it works perfectly :smileyhappy:
    Not sure why it was removed in the newer versions.
    Thanks for your time anyway antinode
