jcalvert's avatar
jcalvert
Can't access single website
I am unable to access https://safetechhawaii.com.  Can't browse to it, can't ping it, and traceroute fails.
The router is not using any site blocking.  I am using ethernet connection only, not wifi.
If I remove the router and plug the modem directly into my computer, I can then access the website.
This is the only website I can't access, and it happens to be a GoDaddy-hosted website.  If I attempt to ping other IPs in GoDaddy's range, they all fail.
The router is using the current version of the firmware.
  • We have determined that this is a bug in the firmware.  I'm going to report this using the Nighthawk app for Android.
      • jcalvert's avatar
        jcalvert
        I am filing the bug report right now, using the Nighthawk app for Android, as I was directed by Netgear tech support today.
        What I found is that the router is misidentifying IP addresses of the form 192.16N.X.Y as private (local) IPs.  It should be looking for 192.168.X.Y, but it looks for 192.16N.X.Y.  So it appears that when an IP has any value of N, 0-9, the IP will be recognized as local, and the routing then fails.  Any website with an IP like this will be inaccessible.
