phree0
Aug 08, 2017Aspirant
can't access Traffic meter
Hello
the first post asking "if" it is possible to update my firmware version which is V1.02.68_60.0.93NA
It would be nice to have the traffic tracking ability.
I hit the search for new update button and it shows it is current.
this router I have had about 2 years and this is the firmware it was updated to on the instal day.
I hope there might be something newer that might have the traffic option?
I am unable to find this on my router genie pages.
the way to find it is:
go to advanced page
then to Advanced setup to find the traffic meter.
the manual is not complete.
you have to open everything until you find what your looking for.
the meter is not very helpful, but its there.for several years my first router choice and recommendation has been netgear -
it seems the best solution is to buy a router from a company that has continued support with firmware updates.
- ElaineMNETGEAR Employee Retired
- phree0Aspirant
thank you
I will need to get the manual as I have this version installed 1.0.2.68_60.0.93NA
shucks I was hoping there was a newer version, Maybe even support? lol
guess it is time to buy a different router that has a better history for ongoing support. - phree0Aspirant
go to advanced page
then to Advamced setup to find the traffic meter.
the meter is not very helpful, but its there.- ElaineMNETGEAR Employee Retired
Unfortunately, there will be no other firmware to be released unless it is a security vulnerability issue.
What do you mean by unable to access Traffic Meter in your initial post?
