matan8
Jan 03, 2018Follower
can't connect smart plug to my router R6400
Hi, I am trying to connect efergy ego (smart plug) to my router (R6400, default security settings), and for some reason I can't do it. When I tried to connect the smart plug using my phone's hotsp...
HansPL
Aug 07, 2022Tutor
I could connect one Teckin smart socket SP10, but not a second one, in spite of doing the same thing.
Hans L
- michaelkenwardAug 08, 2022Guru - Experienced User
You have joined in on an existing conversation that may or may not have anything to do with your problems.
There is also a good chance that the official support team is busily monitoring new conversations and may miss your addition to this one.
If you do want help with your problem, check previous stuff that may be related then start your own discussion.
If you do decide to ask a question, you should provide more details and your own version of the information that the forum suggests that you provide.
