Whiskeydash
Oct 22, 2012Guide
Can't connect to ReadyShare
Hi,
I've spent the last few hours going through pages on this forum and still haven't found a solution to my problem.
I can't access the hard drive connected via usb to my wndr4500 through my wireless network on my pc. It doesn't appear.
On my laptop and tablet devices I have no problems connecting to the router and streaming movies etc off the storage device (2tb).
My pc connects to the router fine and runs internet fine. Accessing the router login page shows the readyshare status as 'ready' and on the readyshare tab I can see the usb drive name, space used etc. Router firmware and network drivers are all updated.
In the advanced settings I have: enabled any usb device to connect, checked the workgroup name, enabled media server with auto scan.
My wireless connection is a home network connection and I cannot find any issues that are stopping me from connecting.
I have a suspicion that this problem is related to my wireless card though i'm not really sure if this is the case or what it might actually be. I have a wnda4100 n900 wireless adaptor.
Wondering what the problem is?
Sorry if this question has already been answered, I couldn't find it. Thanks in advance for any help.
W.
W.
- Aurora420AspirantTest with firewall and anti-virus disabled. If you have to, I mean if just doing that does not help, I would also test with anti-virus program and firewall (If non-windows) removed then reboot and be sure windows firewall is disabled then test again. Just to rule that out as a possible cause.
- Aurora420AspirantAlso, you could try manually entering the share location into windows explorer URL bar (Or IE7/8). This probably will not help if you have something blocking access though.
Below are some examples of what I mean, check in your router and you will see the exact address for the USB drive. It's in the advanced tab, then storage, then advanced storage section
\\readyshare
Or
\\readyshare\Internal_Disk
\\readyshare\USB - Hi, thanks for the suggestions but unfortunately I didn't get anywhere with these. Any other ideas?
- msnancyAspirant
Whiskeydash wrote: Hi, thanks for the suggestions but unfortunately I didn't get anywhere with these. Any other ideas?
Try to install this utility on your computer:
http://netgear.com/assets/landing/readyshare/ReadyShareConnect.exe - Aurora420AspirantYou could also try rebooting the router to see if that helps, if not try a hard reset
- Thanks again for the replies. I installed the map drive software but had no success. I've also tried a hard reset already with no luck.
- Aurora420AspirantWhat happens when you try what I suggested in post #3?
- I get a 404 not found page
- (the path for my readyshare is \\readyshare\USB_Storage)
- Another thing of note is that on my network page where it says media devices beneath my computer name I have 2 media devices showing. The first one is my local computer, however the second one is called Ready DLNA: WNDRA4500 and accessing it brings me to a couple of the files that I have on the storage drive.
Additionally, beneath this is my network infrastructure which shows RalinkAPS and WNDR4500 (Gateway). Clicking on this gateway creates the network map which shows the router, the internet and the wireless printer which is connected through the router.
because of these things I think the problem must be some software setup either in my adaptor settings or elsewhere on my pc (windows 7 u).
