Phases's avatar
Phases
Initiate
Aug 24, 2017
Cant connect to router AC1200
Router wont let me connect to it, when i input password it thinks about it then says 'incorrect password' but when i input random letters it straight away says 'unable to join network', it also wont connect to the internet
  • Problem solved.
    Restored to factory settings
    • michaelkenward's avatar
      michaelkenward
      Well done. Thanks for reporting back.
      Always worth trying, even though some people are allergic to the idea.
