wrightstuff
Nov 19, 2016Follower
cant connect to wifi
I bought a wireless router from a yard sale and the network is a secure network and i dont know the password to connect to it is there anyway i can change or reset the password.
wrightstuff You can always configure your own settings. Reset the router by using a paperclip to push the the reset button then reconfigure the settings by following the steps below.
I cannot access the Internet with my NETGEAR router
- devindrebAspirant
plug it in, push reset button, then use password settings on label on bottom.
admin, password after going to 192.168.0.1
- ElaineMNETGEAR Employee Retired
