Adoregon
Jan 19, 2022Follower
Can't edit or create network folders on USB drive connected to router
I've attached a USB drive to the backside of my WNDR3400v3 router and followed the instructions to connect to it using readyshare. I've renamed the share to \\Router\USB_Storage. It appears in Windows Explorer as it should as a network "computer" and as a disk drive in the list of drives. I've copied files and directories to it, edited them, saved them and deleted them. It all works just fine, EXCEPT when I log into the router and try to edit the share name or create a new folder. When I click on Edit or Create New Folder, the window refreshes with the same information. It doesn't open the Edit/Create window shown in the user manual.
How do I go about editing/creating new folders? Thanks!
1 Reply
Have you come across this?
Solved: ALL Netgear USB Drive Mapping Issues ReadyShareCo... - NETGEAR Communities
