Jh5850's avatar
Jh5850
Follower
Jul 24, 2016
Can't find QoS Priority Rule options for WNR1000v4
The subject pretty much covers it all. I wanted to set up priority rules and manage traffic by using the QoS options in the advanced settings for my router. But there's simply no option for priority rules. Maybe there's something in one of my other settings that somehow blocked it? I'm not sure what the deal is. Any help would be appreciated.
I have a WNR1000v4 wireless router.
screenshot
As you can see there's no option in the QoS settings beyond enable WMM.
  • Retired_Member's avatar
    Retired_Member
    Jul 25, 2016
    Supports Wireless Multimedia (WMM) based QoS  that's it no rules.
    Retired_Member
    • benbuzz790's avatar
      benbuzz790
      I had the same problem and it took many hours to find this post and figure out what was wrong.  Take a look at this screenshot:
      http://i.imgur.com/4WTuRFm.png
      The Help Center clearly indicates that there *should* be more options on the screen, but as you said, they do not exist.  Very bad and confusing design by Netgear here.
      • ElaineM's avatar
        ElaineM
        NETGEAR Employee Retired
        We apologize for any inconvenience this may have caused you.
        I will go ahead and forward your concern to the management but as far as the router is concerned, there will be no future updates that will be available for EOL products.
