thihacr1993
Nov 30, 2020Aspirant
cant find wifi router name
My internet service went out few times today so I had to restart to modem for like the first 2 times and my laptop and my phone was able to reconnect to the wifi just fine. But the last time I had my modem restart, I tried to connec the wifi service on my iphone and my laptop but the wifi name doesn't show up at all. Can anyone help me to fix this issue so I can connect to my wifi again? thank you!
Does it work if you're hardwired in?
What are all the led's showing on it?
Did the wifi on/off button get pushed during the resets? Push and hold it for 2 seconds.
- thihacr1993Aspirant
Does it work if you're hardwired in? - I have not tried hardwired it yet but I'll check it out.
What are all the led's showing on it? - all the led are lighted up except the last 2 icons (one looks like 3 computer connected to each others and one looks like the USB icon)
Did the wifi on/off button get pushed during the resets? Push and hold it for 2 seconds. - I did push and hold it for few second the last time I tried it. The modem lighted up and works fine but no wifi name shown on my laptop and my phone
did it somehow get set back to defaults?
Maybe its broadcasting under a different ssid.
I'd log into it hardwired and check the ssid/password info as well as if it works.
