ZachChap
Nov 24, 2016Aspirant
Can't Get Gigabit Speeds on my WNDR3700v4 Router
I've been having issues with the WNDR3700v4 router we're when I connect my Cat6 cable to any port, then to my PC (That is capable of 1gb/s speeds) I only get 100mb/s speeds, and the router has the am...
- Nov 28, 2016
I'm not sure what else to suggest. One of the 3 is true:
- The cable(s) are defective
- The PC's NIC is defective or is not Gigabit speed
- The WNDR3700v4 is defective
If you are absolutely certain that 1 and 2 are ruled out, then that leaves 3.
TheEther
Nov 24, 2016Guru
Try a different cable.
- ZachChapNov 28, 2016Aspirant
I did but I still get 100mb/s links
- TheEtherNov 28, 2016Guru
