BWSBWS
Mar 26, 2016Aspirant
Can't get password to work for 2.4 GHZ on WPA2-PSK [AES]
I recently updated the firmware on my N600. Now I cannot get the 2.4 ghz band to allow WPA2 encrycption. I've changed the password multiple times, but, no luck. Can login with no encryption or WEP ju...
- Mar 26, 2016
Occasionally, a firmware upgrade uses configuration settings that are incompatible with the old version. Try performing a factory reset and reconfigure by hand. Do not load any configuration file saved by the old version. Be sure to write down or take screenshots of the current settings.
TheEther
Mar 26, 2016Guru
- BWSBWSMar 28, 2016Aspirant
That did the trick. Thank you!
