MargoD's avatar
MargoD
Tutor
Jun 08, 2018
Can't login to R6220 router after firmware update 10 days ago
I installed a firmware update about 10 days ago for my router, and now it won't let me login. I understand I need to do a factory reset, but how do I do that if I can't log in to my router? Concerned...
  • MargoD's avatar
    MargoD
    Jun 09, 2018
    I was able to do a factory reset using the reset button in the back, and now I'm all set. Thanks anyway!
