Andrew78
Sep 03, 2016Tutor
Can't Login to Router on WiFi or with the App
When I am connected to WiFi I cannot login to my R6300 router using the IP Address. I also cannot login using the Genie app from my Samsung Galaxy Note 7. I have the most current firmware on the ro...
- Sep 12, 2016
I found under Advanced Setup -> Remote management. There is a completely different ip address listed there. It is 192.168.0.3 I cannot change that address, at least I don't see where I change it. My network uses 190.168.1.x network. I am able to login to the router while on WiFi and on my phone using the 192.168.0.3 address.
michaelkenward
Sep 05, 2016Guru - Experienced User
I assume that you mean use wireless to login to the web interface to configure the thing rather than just to login to the wiifi.
I ask because it isn't always clear what people mean when they say "login".
Have you tried www.routerlogin.com rather than the IP address?
Both work here, albeit different devices.
Andrew78
Sep 06, 2016Tutor
Yes that is what I mean. I have tried www.routerlogin.com which didn't work, but I will try again when I get home. But the Android App doesn't give you an option for using www.routerlogin.com only IP address. It will not connect at all.
- michaelkenwardSep 06, 2016Guru - Experienced User
Andrew78 wrote:But the Android App doesn't give you an option for using www.routerlogin.com only IP address. It will not connect at all.
That's not my experience. Maybe I am using a different Android app. I have v 2.4.34.
There is a check box that lets me enter the IP address, but I don't use that. I just log in automatically, and it asks me for the password.
- Andrew78Sep 06, 2016Tutor
I have that version too. I have the option to put in my username and password but it never logs in.
