Andrew78
Sep 03, 2016Tutor
Can't Login to Router on WiFi or with the App
When I am connected to WiFi I cannot login to my R6300 router using the IP Address. I also cannot login using the Genie app from my Samsung Galaxy Note 7. I have the most current firmware on the ro...
- Sep 12, 2016
I found under Advanced Setup -> Remote management. There is a completely different ip address listed there. It is 192.168.0.3 I cannot change that address, at least I don't see where I change it. My network uses 190.168.1.x network. I am able to login to the router while on WiFi and on my phone using the 192.168.0.3 address.
Andrew78
Sep 06, 2016Tutor
Yes that is what I mean. I have tried www.routerlogin.com which didn't work, but I will try again when I get home. But the Android App doesn't give you an option for using www.routerlogin.com only IP address. It will not connect at all.
michaelkenward
Sep 06, 2016Guru - Experienced User
Andrew78 wrote:But the Android App doesn't give you an option for using www.routerlogin.com only IP address. It will not connect at all.
That's not my experience. Maybe I am using a different Android app. I have v 2.4.34.
There is a check box that lets me enter the IP address, but I don't use that. I just log in automatically, and it asks me for the password.
- Andrew78Sep 06, 2016Tutor
I have that version too. I have the option to put in my username and password but it never logs in.
