Andrew78
Sep 03, 2016Tutor
Can't Login to Router on WiFi or with the App
When I am connected to WiFi I cannot login to my R6300 router using the IP Address. I also cannot login using the Genie app from my Samsung Galaxy Note 7. I have the most current firmware on the ro...
- Sep 12, 2016
I found under Advanced Setup -> Remote management. There is a completely different ip address listed there. It is 192.168.0.3 I cannot change that address, at least I don't see where I change it. My network uses 190.168.1.x network. I am able to login to the router while on WiFi and on my phone using the 192.168.0.3 address.
michaelkenward
Sep 07, 2016Guru - Experienced User
Andrew78 wrote:
Www.routerlogin.com doesn't work either.
What do you mean by "doesn't work"?
What do you see when you try it?
Which password are you using?
It should be the router login, not the wifi.
First connect to the wifi, then go to the router.
Andrew78
Sep 11, 2016Tutor
When I am on WiFi on my computer and I go to routerlogin.com or the routers IP address it say that it took to long to respond.
I am using my router password when I connect from the phone but it also times out.
- DexterJBSep 11, 2016NETGEAR Moderator
Hi Andrew78,
1. What is the firmware version of the router?
2. Are your wireless devices showing up as connected devices on the attached devices page?
3. Have you tried resetting the router?
Dexter
Community Team
- Andrew78Sep 12, 2016Tutor
1. What is the firmware version of the router? V1.0.2.78_1.0.58 - The latest firmware
2. Are your wireless devices showing up as connected devices on the attached devices page? Yes
3. Have you tried resetting the router? Factory reset or just unplugging it? I have powered it off and turned it on but that didn't make a difference.
