Andrew78's avatar
Sep 03, 2016
Can't Login to Router on WiFi or with the App
When I am connected to WiFi I cannot login to my R6300 router using the IP Address.  I also cannot login using the Genie app from my Samsung Galaxy Note 7.  I have the most current firmware on the ro...
  • Andrew78's avatar
    Andrew78
    Sep 11, 2016
    I found under Advanced Setup -> Remote management.  There is a completely different ip address listed there.  It is 192.168.0.3  I cannot change that address, at least I don't see where I change it.  My network uses 190.168.1.x network.  I am able to login to the router while on WiFi and on my phone using the 192.168.0.3 address.
