Andrew78
Sep 03, 2016Tutor
Can't Login to Router on WiFi or with the App
When I am connected to WiFi I cannot login to my R6300 router using the IP Address. I also cannot login using the Genie app from my Samsung Galaxy Note 7. I have the most current firmware on the ro...
- Sep 12, 2016
I found under Advanced Setup -> Remote management. There is a completely different ip address listed there. It is 192.168.0.3 I cannot change that address, at least I don't see where I change it. My network uses 190.168.1.x network. I am able to login to the router while on WiFi and on my phone using the 192.168.0.3 address.
Andrew78
Sep 12, 2016Tutor
1. What is the firmware version of the router? V1.0.2.78_1.0.58 - The latest firmware
2. Are your wireless devices showing up as connected devices on the attached devices page? Yes
3. Have you tried resetting the router? Factory reset or just unplugging it? I have powered it off and turned it on but that didn't make a difference.
Andrew78
Sep 12, 2016Tutor
