goarv
May 31, 2020Tutor
Can't login to www.routerlogin.net.
I want to change my network name/password from the default setting, and I can't log in to www.routerlogin.net,. or the IP address. I have tried to delete history using both Chrome, and Internet. Any suggestions? Thank you!
- If you can't connect to routerlogin.com or routerlogin.net, try these troubleshooting steps: - 1. Turn on the power for the Netgear router.
 2. Connect a computer to the router's Wi-Fi network.
 3. Connect to the websites using the router's default IP address at http://192.168.1.1. This won't work if you changed the default IP.
 4. If problems persist, connect with a different browser or wireless device.
 5. Power-cycle the entire network.
 6. If all else fails, perform a factory reset on the router.- I hope it might help to solve your problem.
 6. If all else fails, perform a factory reset on the router.- I hope it might help to solve your problem. - goarvTutorThank you! I will try this tonight, appreciate your help.
- JHoganInitiateHi, if the www.routerlogin.net doesn't work you can try logging in with the router's default IP. If you are using Windows you can easily find it via the Command Prompt and typing ipconfig in it. When the results show up just scroll down and you will see your router IP as Default Gateway. Try this.
