Gabreil
May 10, 2020Aspirant
Can't port forward
Hello, for the past year or so I've been trying to port forward the port 25565 to host a dedicated Minecraft server for me and my friends. I was always able to join with my local ipv4 address but my friends couldn't join with my public IP. I never got it to work and gave up after following all the steps I could find in forums with people having the same problem as I was. Recently I've tried to host a dedicated Terraria server instead (port 7777), but same problem there, the port just does not want to open.
I've used several port checker websites and the PortForward software from https://portforward.com/ but it always says the port is closed.
I think it's worth mentioning that I had no problem whatsoever port forwarding the port 25565 with my last router. It was an ASUS Router, which I can't remember the name of.
I would be forever thankful if anyone could help me solve this issue, please ask me for more information/specifications if it is needed.
Router: NETGEAR R6220, Router Firmware Version V1.1.0.86_1.0.1
> If you look at the picture I uploaded, you can see that the question
> "Does your Internet connection require a login?" is answered No. [...]That's an argument between you and your ISP. If you have Internet
access, then that's not the problem.But, while we're looking at that picture...
> https://community.netgear.com/t5/x/x/m-p/1859106
> Does the IP address of the WAN/Internet interface of your router
> match what you're using as your public IP address from the outside
> world? ADVANCED > ADVANCED Home : Internet Port : Internet IP AddressBASIC > Internet : Internet IP Address : IP Address (as shown in your
picture) provides the same critical fact: 100.68.<blur>.<blur>. Plug
that address into the form at: https://whois.arin.net/ .As you can see, that's not a public IP address. My guess would be
that your ISP is using carrier-grade NAT, and that's defeating your
attempts at port forwarding.https://en.wikipedia.org/wiki/Carrier-grade_NAT
The only solutions I know are: 1) to ask your ISP for a real public
address (for which they might charge more), or 2) to use a tunneling
service like the one mentioned in another thread (near the end):https://community.netgear.com/t5/x/x/m-p/1748431
Some ISPs do not permit servers for residential customers, but I'm
confident that they'll tell you that if you ask.
Connected to what?
- GabreilAspirant
What do you mean, I don't understand which part of the text you're referring to.
> referring to.Pretty much all of it. Start at "The usual problems with this stuff
are:", and answer the questions?
