mapcat
Jul 16, 2018Tutor
Can't rename 5G network
Today my antivirus prompted me to upgrade this router's firmware, and with that came a factory reset of the router. I'm in the process of renaming the networks and resetting the passwords and can't r...
- Jul 16, 2018
nvm, apparently this can't be done in the "genie". I got it to work via http://www.routerlogin.net/
mapcat
Jul 16, 2018Tutor
antinode
Jul 16, 2018Guru
> [...] apparently this can't be done in the "genie". I got it to work
Ah. Normally, when someone says "Genie", I include boilerplate like
the following:
Which "the Genie"? Ever helpful, Netgear uses the name "Genie"
for more than one thing. Netgear routers have a web-browser
interface called "Genie", and Netgear offers application programs
for various computers/pads/phones, which are also called "Genie".
Your "Genie UI" left me believing that you were using the web-browser
interface, not one of the Genie apps.
I don't use the Genie apps, so I know nothing, but I would not be
amazed if such an app refused to reconfigute the network interface which
it was using to control the router.
Primary lesson: "Genie" is not a complete description of anything.
(And, as always, "Never assume."
https://www.youtube.com/watch?v=pEoFFYH_m0Q )
