  • michaelkenward's avatar
    michaelkenward
    fillipov wrote:
    Trying to update 6300v2 router but it says file is incorrect.
    Your subject isn't clear. Which 6300v2 ? R, C or D.
    Probably the R6300v2 – just checking.
    What says "file is incorrect"? How are you going about the update?
    This is the best approach:
    How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
    Remember, the download is a zip file that you have to unpack. You then have to "load" the firmware file into the router. You cant just "open" it.
  • plemans's avatar
    What firmware is actually on it?
    There was a R6300v2 that was direct sold to ISP's with the ISP's own firmware on it.
    So knowing what version your on helps to determine if it was one of those R6300v2s.
