smk613's avatar
smk613
Cascading R6400 Routers
I am trying to cascade eo R6400 to expand the network. I woukd like to connect the WAN port from the seond router to the LAN port of the primary rouer via cable. Will it et an automatice IP addres fr...
  • DexterJB's avatar
    DexterJB
    Jan 05, 2017
    Hi smk613,
    If the R6400 was configured as an AP then you will need to use the IP address assigned to it by the main router.
    Dexter
    Community Team
