smk613
Jan 02, 2017Aspirant
Cascading R6400 Routers
I am trying to cascade eo R6400 to expand the network. I woukd like to connect the WAN port from the seond router to the LAN port of the primary rouer via cable. Will it et an automatice IP addres fr...
smk613
Hi
Maybe you can help. I have internet access now. I am not sure hw it configured itself. I cannot see it on the Optimum,net networks map and I can not get to the second router - i.e. genie cannot get at it and if i try to use www.routerlogin.net it gets grabbed by optimum and I see that router.
Thanks
