JimHolman
Nov 28, 2020Aspirant
CBR40 Firmware file is corrupt on the website
Could someone please confirm for me the firmware file here is corrupt:
https://www.netgear.com/support/product/CBR40.aspx#download
> [...]I doubt it. _Which_ "the firmware file" there? What did you do with
it? "CBR40-V2.5.0.14.zip" looks fine to me:$ unzip -l CBR40-V2.5.0.14.zip Archive: CBR40-V2.5.0.14.zip Length Date Time Name --------- ---------- ----- ---- 40119162 10-23-2020 03:29 CBR40-V2.5.0.14.chk 809 10-23-2020 03:38 CBR40-V2.5.0.1_Release_Notes.html --------- ------- 40119971 2 filesPerhaps it would help if you revealed how you came to that
conclusion."corrupt" is not a useful problem description. It does not say what
you did. It does not say what happened when you did it. As usual,
showing actual actions (commands) with their actual results (error
messages, LED indicators, ...) can be more helpful than vague
descriptions or interpretations.https://community.netgear.com/t5/x/x/m-p/1721037#M124018
Visit http://netgear.com/support , put in your model number, and look
for Downloads. (For older versions, under Firmware and Software
Downloads, look for "View Previous Versions".) Find the kit(s).
Download the kit(s) you want. Read the "Release Notes" file for
instructions. (In the User Manual, look for "firmware", and,
especially, for a topic like "Manually Upload Firmware to the Router".)
When that fails because of a deficient User Manual, try:- JimHolmanAspirant
Twice earlier yesterday I downloaded new firmware for my RBR50 & RBS50. The downloaded zip files contained .IMG files which worked perfectly to update the 2 units firmware. As you note the downloaded zip for the CBR40 contains a .CHK file. In the old DOS days that indicated a bad checksum in the file. Are you suggesting that the CHK file can be used to update a firmware?
- JimHolmanAspirant
Never mind. I see it here now:
https://www.file-extensions.org/chk-file-extension
Netgear does indeed use both .IMG & .CHK as valid file extensions for a firmware updates. Guess I have been around too long. CHK used to mean trouble.
What suggests that this is the case?
Start with a description of what is going on at your end rather than with you thinking in why it happens.
This might be useful:
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
It describes steps that you may have missed out.
You might get more help, and find earlier questions and answers about your hardware, in the appropriate section for your device. That's probably here:
Orbi - NETGEAR Communities
