ckbeme
Mar 24, 2017Aspirant
Cell Phones are showing on my Network Folder, but not showing in Router software
I have had this router installed for about a year. Randomly I have cell phones showing up in my Network Folder on my PC (either of them). These are not showing in the attached devices on my Router so...
- Apr 28, 2017
This is a question which pops up frequently, and on many forums. I had this question over a year ago, when I noticed many phones (and even an Android TV) on my PC network folder. It seemed that only Android devices showed up. But the devices are not connected to the network, since they do not get any IP address from the router. So, there is nothing to worry about.
What happens is that if a person with a phone (with WiFi on) passes your network, the phone may briefly show up on your network folder. The person with this phone has no idea about it. Likewise, if you have a phone and walks by a house, your phone may show up on somebody’s PC.
The suggested solution to this is to go into Services on the PC and disable “Windows Connect Now”. Since I did this, I have not seen any phones (or other strange devices) any more.
But it is still a mystery to me why the router (and not only Netgear routers) passes this information to the PC. What can the PC use it for?
TheEther
Apr 28, 2017Guru
Is your Wi-Fi network set up with a password? Are you using WPA2 security?
