toddincharlotte's avatar
Nov 27, 2016
Centria as Stand-Alone NAS
Hey All,   New to the forum.  Have had really good luck with streaming off my Netgear Centria in the past but my family has switched to a new setup.   We recently got an upgrade in service fr...
  • ElaineM's avatar
    ElaineM
    Dec 01, 2016
    The router should still be accessible even if it's not connected to any modem.
    You can still access the admin page with or without Internet access.
    If you will be connecting through wireless, then same process and ReadySHARE should still be available just like before.
    When you connect to the wireless, see if you are getting an IP address from the router.
    If you do, then you should be able to access the admin page.
