toddincharlotte
Nov 27, 2016Aspirant
Centria as Stand-Alone NAS
Hey All,
New to the forum. Have had really good luck with streaming off my Netgear Centria in the past but my family has switched to a new setup.
We recently got an upgrade in service fr...
- Dec 01, 2016
The router should still be accessible even if it's not connected to any modem.
You can still access the admin page with or without Internet access.
If you will be connecting through wireless, then same process and ReadySHARE should still be available just like before.
When you connect to the wireless, see if you are getting an IP address from the router.
If you do, then you should be able to access the admin page.
toddincharlotte
Nov 29, 2016Aspirant
BUMP
ElaineM
Nov 30, 2016NETGEAR Employee Retired
Try configure the following on the Centria.
- Change the LAN IP of the Centria and make it in the same range as the main router
- Configure the wireless settings (just in case you still need to use the wireless portion)
- Disable DHCP
- Connect the main router to one of the LAN ports on the Centria
Once you have done the following, see if you can access the attached storage.
- toddincharlotteNov 30, 2016Aspirant
ElaineM wrote:Try configure the following on the Centria.
- Disable DHCP
- Disable DHCP
Hey Elaine,
I appreciate the input.
Sorry I was unclear.
- This Centria will be a stand-alone wi-fi router that will not be connected to a main router and not be connected to the internet
- The Centria's sole purpose will be to broadcast streaming media to locations throughout our home [WDTV pull].
This had worked fine in the past when connected to our cable modem and acting as broadcast for both NAS files and internet, however, without an internet connection, I am unable to access files and cannot even login to router settings.
- ElaineMDec 01, 2016NETGEAR Employee Retired
