egm2901's avatar
egm2901
Initiate
May 31, 2018
change admin password
  Trying to change admin password through "Advanced."  When I go to old password box, Firefox/Mozilla shows warning that website is insecure.  Is it possible to enter old admin password quickly and...
  • antinode's avatar
    May 31, 2018
    > [...] When I go to old password box, Firefox/Mozilla shows warning
    > that website is insecure. [...]
       It would do that because it's worried about your sending some user
    credentials over an unencrypted/insecure link ("http://" instead of
    "https://").  The easy thing to do is ignore the warning, and proceed.
    Presumably, you're talking to your own gizmo on your own LAN.  If
    someone can overlisten to that traffic, then you're already in big
    trouble.
