lindaloodle
Nov 15, 2016Aspirant
Changed password, laptop does not connect to WIFI
I changed my password for routeras my new security system told me it was weak. On NetGear Genie, all looks like it is working. I connected my Android Nook by inserting new password and it is fin...
- Nov 15, 2016
I was able to solve this issue by going onto the Windows 7 forums and found that I needed to delete the WIFI account that I had originally created. Then reinsert it with the new password. It all worked and is up and running.
VE6CGX
Nov 15, 2016Master
When you tried to connect what message do you get? What is the model of WiFi card in the laptop? What password protocol, WPA2-AES? Some OLD WiFi card is not compatible with newer WPA2-AES protocol. Also see if the WiFi card has new driver available.
- lindaloodleNov 15, 2016Aspirant
Hello,
Thanks for getting back to me.
Message: "Ethernet cable is not properly plugged in or might be broken." Just got this one for first time today while rechecking this after you asked these questions.
Message: "Windows cannot resolve your wireless connectivity issue." This has been the message all morning.
Password Protocol: WPA-PSK(TKIP)+WPA2-PSK(AES)
I do not find a WIFI card. I did find driver and checked for up-to-date and it is.
