ClayL
Jan 25, 2017Aspirant
Changing usb storage drive number
Firmware V1.0.1.18_1.0.15 Lenovo Desktop Win10 64 bit The drive I first used for readyshare shows up as the Z drive in File Explorer. I want to change drives and the new drive is assigned T. The dr...
- Jan 25, 2017
ClayL wrote:
I meant drive letter not number
Your workaround is fine, but I think you are a bit confused.
You can map a network share (\\readyshare\drive_T) to a drive letter in Windows if you want. The drive letter you use is managed by Windows, not the router. It has nothing to do with disk management, because the drives aren't connected to your PC.
Instructions for Windows 10 are here: http://www.laptopmag.com/articles/map-network-drive-windows-10 There are similar guides out there for other versions of Windows.
ClayL
Two things - I meant drive letter not number
My router is a R6400.
I looked at Windows Disk Management/actions but neither the T drive or the old Z drive is listed. And there are no change a drive letter actions listed.
Right now I have a workaround - Went to Network/readyshare/drive_T and made a desktop short cut to it. That lets me access the readyshare T Drive. It's less clicks than opening "This PC" anyway.
Jan 25, 2017Guru - Experienced User
- ClayLJan 25, 2017Aspirant
That worked! Thanks!
