jaeholme
Jun 04, 2017Tutor
Configure Router for VPN
I'm trying to configure my router to connect to a VPN. I'd like to use VPN for any device on my network which is why I'm trying to connect my router to a VPN instead of the individual devices. The ...
- Jun 05, 2017
Welcome to the community, jaeholme
The router doesn't support VPN hence you can't see any VPN feature anywhere on the screen.
You may probably have to use a different hardware in order to use VPN.
The only VPN that it supports is VPN passthrough.
Note: The model number WNDR3400v2 supports VPN Passthrough
ElaineM
Jun 05, 2017NETGEAR Employee Retired
- William10aJun 05, 2017Master
The only chonce is a third party firmware Have seen wndr3400v1's running dd-wrt firmware they seem to work ok may be the v2 version can run dd-wrt so well if it does you may be able to the vpn you want.
