jaeholme's avatar
Jun 04, 2017
Configure Router for VPN
I'm trying to configure my router to connect to a VPN.  I'd like to use VPN for any device on my network which is why I'm trying to connect my router to a VPN instead of the individual devices.  The ...
  • ElaineM's avatar
    Jun 05, 2017
    Welcome to the community, jaeholme
    The router doesn't support VPN hence you can't see any VPN feature anywhere on the screen.
    You may probably have to use a different hardware in order to use VPN.
    The only VPN that it supports is VPN passthrough.
    Note: The model number WNDR3400v2 supports VPN Passthrough
    Troubleshooting VPN passthrough for home routers
