Amitami's avatar
Amitami
Connect 2 RBK752 systems
Hi,
I have already a AX4200 router wired to the modem with a satellite.
Can I add a second AX4200 router and satellite to the same mesh network?
The second router should in best case not be wired to the modem or first ax4200 router
If yes, how?
  • Did you get this figured out? I'm trying to do the exact same thing and can't figure it out. I thought i could purchase 2 RBK752 sets and link them into one mesh network.
    Thanks,
    Stephen
    • Amitami's avatar
      Amitami
      Hi, unfortunately you can't connect 2 routers in the same mesh network as the router cannot act as a satellite. However, you can built a second network wired only with the router.
