wbbest
Mar 06, 2018Tutor
connect old WNDR3400 router to new R7000P NightHawk
I upgraded my WNDR3400 Router to a new R7000P NightHawk Router to be able to stream video better. My problem is that now my older HP 6980 printer cant see the new router because as I have checked is...
- Mar 06, 2018
finally got printer connected. Had to connect via ethernet, print a report page to get a IP address, open a browser and connect to that ip, then setup the wireless SSID and paraphrase, then disconnect the ethernet & print another report, getting a new IP, then set up that TCP/IP port for the printer.
wbbest
Mar 06, 2018Tutor
I disconnected my old WNDR3400 and connected my new R7000P. I have 2 printers connected wirelessly. my newest Epson XP830 Connected to new router with no porblem. When connecting my older HP 6980 my computer can't see the printer. I have tried connecting a usb to connect wirelessly as well as connected via usb and then changing to wifi but it never connects. There is no lcd pannel on this printer it is a older deskjet printer only. The blue wifi light is on but nothing connects
wbbest
Mar 06, 2018Tutor
- antinodeMar 06, 2018Guru
> [...] I have tried connecting a usb to connect wirelessly as well as
> only. [...]
Knowing nothing, I assume that this thing came with some HP software
to let you configure the wireless stuff while connected by USB.
Thanks for the report. Sure. If the thing has a web server, then
all you should need to do is find it. (What could go wrong?)
> [...] print another report, getting a new IP, then set up that TCP/IP
Bear in mind that if you expect the printer's wireless interface
always to have the same IP address, then you'll probably want to reserve
an address for it on the router.
If you don't already have the User Manual for your router, then visit
http://netgear.com/support , put in your model number, and look for
Documentation. Get the User Manual. Look for "Address Reservation".
It's that, or else configure the printer's interface with a static IP
address, but in that case, you'd want its address to be outside the
router's DHCP pool (LAN Setup > Starting IP Address, Ending IP Address).
Assigning a static address from the DHCP pool risks the router's DHCP
server handing out that address while the printer's powered off, and
then having a conflict when it's powered on.
