Smbo
Mar 25, 2022Follower
Connect to landline
Is this possible on this model? Please advise in non-technical terms! Thank you
michaelkenward
Mar 26, 2022Guru - Experienced User
What do you mean by "Connect to landline"?
If you want to plug a telephone into the router, then the answer is no.
For that you normally want to buy a modem or modem/router that supports voice. But not all Internet service providers will work with voice modems.
If you want to plug an internet service into the thing, then you need a modem.
So, back to you, what do you want to do?
