mattcott77
Jul 04, 2022Aspirant
Connected to WiFi but no internet
I’m using a DM200 VDSL modem and an N600 WNDR3400v3 router. When I restarted both, I think it reset to factory settings. I was able to log into routerlogin.net. On the home page, internet status is “g...
mattcott77
Sorry, I’m not following…
I don’t see the settings you mentioned. Do I find them on routerlogin.net? I’m currently logged in and it looks like I have the settings for the WNDR3400v3. There’s an option under WAN settings-> NAT filtering to disable SIP ALG. Do I check that box? Do I need to log in somewhere else to get the settings for the DM200? Thanks!
Jul 04, 2022Guru - Experienced User
disconnect the router from the dm200.
then connect a pc/laptop to the dm200 and try the routerlogin address. or use its ip address.
DM200 | Product | Support | NETGEAR
