mattcott77
Jul 04, 2022Aspirant
Connected to WiFi but no internet
I’m using a DM200 VDSL modem and an N600 WNDR3400v3 router. When I restarted both, I think it reset to factory settings. I was able to log into routerlogin.net. On the home page, internet status is “g...
mattcott77
Sorry, I’m not following…
I don’t see the settings you mentioned. Do I find them on routerlogin.net? I’m currently logged in and it looks like I have the settings for the WNDR3400v3. There’s an option under WAN settings-> NAT filtering to disable SIP ALG. Do I check that box? Do I need to log in somewhere else to get the settings for the DM200? Thanks!
michaelkenward
Jul 05, 2022Guru - Experienced User
As plemans says, the DM200 has to be in modem only mode. Do that before you add the router to your network,
To read how to achieve that, scan the Quick Start guide in the support section.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Begin with the Quick Start/Installation Guide.
Read the bit:
(Advanced) Set Up Your DSL Modem as a Modem Only
