bobpetit
Jul 20, 2016Aspirant
Connecting a WNDR4500v3 router to a Toshiba FlashAir W-02
Has anyone had success connecting a Toshiba FlashAir SDCARD to this router. My router sees the card and shows it in the list of connected devices but the router will not give it an IP address. It jus...
- Jul 21, 2016
It finally started working. I added a few more options to the config file manually and it finally connected.
bobpetit
Jul 21, 2016Aspirant
ElaineM
Jul 21, 2016NETGEAR Employee Retired
Can you share what additional things you have added?
- bobpetitJul 26, 2016Aspirant
This is what my config file looks like. It finally worked but still seems to disconnect eventually. With APPAUTOTIME=0 its supposed to stay connected and not drop. I've tried setting the value to the max number and it still eventually disconnects when idle
[Vendor]
APPMODE=5
APPNAME=myflashair
APPSSID=(your router name)
APPNETWORKKEY=(your router passwrod)
APPAUTOTIME=0
BRGSSID=(your router name)
BRGNETWORKKEY=(your router password)
CIPATH=/DCIM/100__TSB/FA000001.JPG
VERSION=F19BAW3AW2.00.02
CID=02544d535731364708da26d57800e401
PRODUCT=FlashAir
VENDOR=TOSHIBA
MASTERCODE=7c5cf8950f29
LOCK=1
DNSMODE=1
UPLOAD=1- ElaineMJul 27, 2016NETGEAR Employee Retired
Have you tried using the SD Card to a different wifi network?
