DnetG's avatar
DnetG
Constant Connection Timeout Error N300/C3000 Cable Modem Router
I've been using the Netgear router (N300/C3000) for about 4 years and recently, about 6 months ago, its began to timeout. The error I receive on and off is below. Any suggestion on a fix? Thanks!
Missing BP Configuration Setting TLV Type: 17.9;CM-MAC=b0:7f:b9:e0:22:f8;CMTS-MAC=00:01:5c:8b:f8:4f;CM-QOS=1.1;CM-VER=3.0;
  • usually means theres issues with your signal.
    Log into the modem part and take a screen snip of your modem upload/download connections page. This shows us signal strengths and errors to see if its an issue with the line.
    also remove any splitters, amplifiers, attenuators from your line. Prefereably move the C3000 to directly where the line enters the home so it avoids a damaged coax within the home causing the issue.
  • plemans's avatar
    • DnetG's avatar
      DnetG
      Thank you for the response. There are no splitters, amplifiers, or attenuators on the line. It is also a direct line and the modem is about two feet from where the coaxial enters the home. I've had a Spectrum tech come out and inspect the line and of course that day the connection didn't act up and he simply tested the line for about 5 minutes and everything was okay. He suggested to replace the modem. Is that something that I should try?
      Also is this what you mean by "upload/download connections page"?
      • plemans's avatar
        I put a link to what the modem connections page should look like.
