chiffshinz
Jan 31, 2017Aspirant
Control R6100 via Command Line Interface
As said in the title, I would like to do some tasks via a CLI. In the manual I wasn't able to find any information about a Command Line feature. Does this mean there is no such feature?
- Jan 31, 2017
I've never seen any documentation for this. But you could perhaps take a wireshark trace, and see what the browser sends when you enable/disable wifi. There might be some other settings in the mix that you'd also need to re-send.
VE6CGX
Jan 31, 2017Master
What are you trying to do? Are you familiar with Linux?
- chiffshinzJan 31, 2017Aspirant
Thanks for the response :)
I want to host a website which is available over the internet which contains a button for setting the wireless on and off.
The idea is, that family & me can set the wifi on and off from our mobile phones over cellular data.
The server is connected to the router. My only problem now is, that I want to execute a script against the router when this button is pressed.
I'm familiar with web technologies and security and also unix systems.
Hope that this clarifies some things.
- StephenBJan 31, 2017Guru - Experienced User
