chiffshinz
Jan 31, 2017Aspirant
Control R6100 via Command Line Interface
As said in the title, I would like to do some tasks via a CLI. In the manual I wasn't able to find any information about a Command Line feature. Does this mean there is no such feature?
- Jan 31, 2017
I've never seen any documentation for this. But you could perhaps take a wireshark trace, and see what the browser sends when you enable/disable wifi. There might be some other settings in the mix that you'd also need to re-send.
chiffshinz
Yeah I think I'll stick to that.
I already investigated the initial request wich has basic http authentication realm. I was able to replicate the request and got a response from the router.
I also found out, that my Router supports the Genie App which communicates via SOAP. Maybe I could also do it that way and implememt further functionalities much easier and less painfull.
Anyways, thank you guys for the fast responses.
Cheers.
Cheers.
