Tall-Eric
Oct 30, 2016Tutor
Corrupt firmware, tried reset, can't ping router (WNDR4500/N900)
We had a power outage at our home, after that the N900/WNDR4500 router power light started blinking green which indicates there is a firmware issue. Reseting the router didn't correct, connection to ...
- Retired_MemberOct 30, 2016
https://community.netgear.com/t5/General-WiFi-Routers/Trouble-with-firmware-update/m-p/475334#M48728
read this thread it may help
Retired_Member
Oct 30, 2016https://community.netgear.com/t5/General-WiFi-Routers/Trouble-with-firmware-update/m-p/475334#M48728
Tall-Eric
Oct 30, 2016Tutor
Huge thanks searay! Forcing the PC to 192.168.1.2 & using the windows tftp command line utility to force the update worked (the Windows GUI tftp2 tool I downloaded did not, nothing at the GUI level seemed to see 192.168.1.1 as available)
Much appriciate the support and pointer! Thanks again!
Good Work!
You're Welcome!
