CliveB's avatar
CliveB
Follower
Aug 29, 2019
D6400 firmware upgrades fails
Have tried upgrading to D6400-V1.0.0.88_1.0.88.chk via the router and via my mac from a dowloaded file. It seems to download but the little blue picture keeps on turning and it never finishes. Works OK when I exit the router but its still on V1.0.0.86
Why does it not go through. Have tried several times
  • > [...] via the router and via my mac from a dowloaded file. [...]
       That tells me nothing.  What, exactly, did you do?
    > [...] D6400-V1.0.0.88_1.0.88.chk [...]
       Presumably, if you got that file, then you also got the Release Notes
    file, which points to the D6400 User Manual.  Look for "Manually Upload
    New Firmware and Update the Modem Router"?
1 Reply
