ZanK's avatar
ZanK
Deactivation of the wifi
when I activate the function 'Turn off wireless signal by schedule' the router deactivate just the broadcast of the SSID or completely deactivate the wireless signal from the router?
  • It should completely deactivate the wireless signal and not just the SSID
  • plemans's avatar
    • ZanK's avatar
      ZanK
      So there should not be any wireless interferences right?
      • plemans's avatar
        From that specific device. There might be others in your area broadcasting. I feel like I'm being led on......
