tantony's avatar
tantony
Luminary
Oct 15, 2018
Default gateway on WiFi router
If I go to LAN Setup, I can configure static IP for this WiFi router, but how do I add the default router?  The IP Address is 172.16.128..  IP Subnet Mask is 255.255.192.0, but I don't see a Default Gateway option.
Also, it won't let me edit the DHCP scope.  I can only do from 172.16.128.4 - 172.16.128.254.  But, I want it to be 172.16.151.1 - 172.16.151.254
  • I don't have the bigger, global picture. For a router operating in router mode, the router is the default gateway. For routers operating in WLAN AP mode only, features like the DHCP server won't be available - but of course the management interface is able to take a single static default gateway address.
  • schumaku's avatar
    schumaku
    Well, these routers are designed and implemented for dead simple usage, the router itself is the default gateway, anything beyond of 255.255.255.0 can't be configured on the DHCP server, ...
    • tantony's avatar
      tantony
      Luminary
      Are there Netgear WiFi routers where I can put in the default gateway and DHCP?  Or is this the same for ALL WiFi routers?
      • schumaku's avatar
        schumaku
