Tanis143's avatar
Tanis143
delayed wireless access
Ok, this is a weird issue, not something I've seen before. All my wireless devices (three android phones [one S5 and two S7s] and a Tab4 tablet) show this same issue. It will show a wireless connection but when you try to access the internet the connection will hang for about 30-60 seconds then start working. It will continue to work unless you let it sit for about a minute then it does the hang again. This only happens on the wireless, my wired connections work just fine (four pc's, one on win7 the rest on win10). I already have the most up to date firmware (1.0.1.14). I know of no other settings that would cause this issue and google search hasn't pulled up another issue like this. Any idea's?
  • I just said screw it and bought a new router. Got the Netgear R6300v2. Since I work for my ISP I got it at a good discount. The difference has been incredible. My wireless speeds are no different than my wired speeds in all areas of my house.
  • Retired_Member's avatar
    Retired_Member
    Try using address reservations for the wireless devices
    setup.... lan setup
    The symptom you describe, sounds like DFS (Dynamic Frequency Selection). Try selecting a higher 5 ghz channel, and re-test.
        Retired_Member
        Try another FW version, did this just start happening? If new router return it or contact support.
