manishmanwal51's avatar
Dec 26, 2018
DHCP ISSUE in wnr1000
Hi all,
we have netgear wireless router model wnr1000. we connecet it in different vlan. i want to give all devices that are connected to this device ip address through dhcp server, but the dhcp server for access point vlan is run on our core switch( cisco 3850). we disable dhcp in wireless router. and try to take ip from it , but it is not working. so what configuation we have to do on it.
please suggest
  • no need to reset. its my fault i have configure wrong netwok in dhcp pool. i configure 10.20.30.0/27 and gatway is 10.20.30.40. the gatway ip is reside in another subnet, that is only reason. i did it in right way. now working. thanks.
  • You might try resetting the wnr1000 and doing your configuration over again.
    • manishmanwal51's avatar
      manishmanwal51
